A little help plz!!??!?!?!?
I had a hyper 7 that i got rid of but i took the clutch assembly from the engine that was in the hyper 7 and put it on my new RB s7 engine that im about to drop into a MBX6. Is this a good idea or should I use a mbx6 clutch assembly?
Also when I go to install my throttle servo there doesnt appear to be anything for the screws to screw into? Any and all help is greatly appreciated! |
Originally Posted by crockpot7
(Post 7065862)
Also when I go to install my throttle servo there doesnt appear to be anything for the screws to screw into? Any and all help is greatly appreciated! If the flywheel is too big it will hit the ground on big jumps and could kill the engine. If it is too small it won't engage the starter box, which won't allow it to start.. |
the clutch bell may be too short or long and not sit centered on the spur, the spur/clutchbell mesh may not be smooth. you can use 3mm nuts on the bottom of the throttle servo screws.
Originally Posted by j_blaze14
(Post 7065934)
no one waste your time helping this guy. check trader feedback forum for details.
