Sweep Racing Tires 1/8th offroad thread
#1186
Hello, I am an AKA iBeam user. Our LHS has Sweep. Since the price is great, I dont want to pass on them. Can you tell me which patterns/compound works almost as closely as iBeams?
Our track is loose and is no where as hard packed as US tracks. A video to show the surface.
http://m.youtube.com/watch?v=FZxkdoNOvXM
Please help.
Please help.
#1187
Battle Star, silver and blue compound
Please help.
Please help.
#1188
Silver Battle stars or silver double actions should do the trick!!
#1190
Please help.
Please help.
#1191
2013 FEMCA Sweeped!
Dani Choi and Ryan Lee left a absent note on their desk at Sweep Racing last week to go play in dirt!
well...our boys done what they do best in a play ground.
Dani Choi TQ 2013 FEMCA over IFMAR world champions!
and QUAL 10th by Ryan Lee! our Prez in global marketing also showing his skillz.
GO FAST & Sweep'em ALL! (from top to bottom!)
#1192
How have people found the Cubix tyres so far.?
I was looking at getting some when they become available in Australia soon but just wanted to see what others think.
#1193
#1194
Cubix have been great. Amazing forward bite and lateral grip. Next to zero tire fade as well during 30 minute mains. But if your track blows out or is rain rutted in the turns this is not the tire to run.
#1195
I have Exagons, Square Armors & just got some Battle Stars as well, all in silver compound, what conditions best suit these tyres as well as the Cubix.
Thanks.
#1196
Ok thanks, they sound good, but the track I go to has a few rough sections, & in some parts it has a bit of loose stuff on a hard packed clay base when the track is dry, (a little soft when damp or wet, its winter here), it gets a bit of a clean racing line after a few rounds but off the line it gets a bit slippery.
Thanks.
Thanks.
Try Double Actions in either blue or red compounds, otherwise the Square Armors will be OK as well. We have found you need to go at least 1 compound stiffer in the Double Actions compared to Exagon or Square Armors.
The Exagons might be a bit edgy for the above track, Aaron is not a real big fan of the Battle Stars so I can't really comment on them
Cheers
Mark
#1197
HI Ozziii,
Cheers
Mark
Cheers
Mark
I found the Square Armors to be good when last at the track, (Shepparton) but the surface was a bit moist & soft so wasn't sure how they would be when dry, loose & rough. I want to go try out the Barmah track next week as well so hoping the Sweeps will do ok there to.
Thanks.
#1198
Thanks Mark, I might do that & grab some Double Actions in Blue & try them as well.
Thanks.
Thanks.
Cheers
Mark
#1199
Square Armors will still be fine on the drier track, although still think double actions will be a bit more forgiving. BTW there is not much difference in compounds between red and blue, they are quite close compared say to going from silver to blue or red to white
Cheers
Mark
Cheers
Mark
I think its the AKA I-Beams & Impacts that work well at Shepparton, not sure about Barmah though, may be the same.
Paul.
#1200
Ok thats good to know then, thanks for that, hopefully I can get the Double actions here by next weekend, ACE has some left in stock so there going to put them on the other shops website. I thought I would go with the Blue compound as I'm still trying to get my buggy setup better so having good traction really helps, plus I haven't had much practice so hopefully having the right tires will make a difference.
Paul.
Paul.
I use that set up at my track and it is the same as the track you said
Work real good that's all I use
