futaba 3pk super questions
I bought a used one. Works great but I can not figure out how to reverse the servos. Also when I try to change models I cant get it to change. Meaning I can get it to go to the screen to change models for one to the other but is there enter button to change?
Originally Posted by tony montana
(Post 7001264)
I bought a used one. Works great but I can not figure out how to reverse the servos. Also when I try to change models I cant get it to change. Meaning I can get it to go to model what ever but is there a enter button I need to push
the model reversing is under the menu under CH-REV.....and for the model selecting you need to select which model and press the +/- button's together at the same time...then turn the remote off then On and you will be on That model. |
ok cool thanks alot. I have been trying to fiqure it out for a while now lol. Just this radio is much different than my ko helios
OK,
To reverse the servos: Turn on, Press the middle button in front of the display (the biggest one) This brings up menu 1. Go across untill you find REV press the middle button again. This brings up your servos Select which one you want to revers and press either the + or - button to change it. End button will take you back to previous screen. Change models: Same thing, Press middle button to get to screen 1 Go across until you find *M-SEL Press middle button. A list of all models you have listed wil come up Find wich one you want. Press and hold both the + and - buttons together for a few seconds and it will select that model. Hope this helps. |
Dam, Integra bet me to it.
one more question. How do I get the big futaba thing back up on the main screen
(Post 7001523)
under system if i remember correctly. :nod: |
