NEW AGAMA A8 BUGGGY > NEW AGAMA A8 BUGGGY
NEW AGAMA A8 BUGGGY
Old 05-18-2011, 04:03 PM
  #4351
rallyebmx's Avatar
Trader Rating: 21 (100%+)
Originally Posted by Jaz240 View Post
yea I would shim per gene's instructions. i think Diff fluid plays a huge role also. The harder your gears slam into each other with thick oils the more wear they will have. you were at 7000 front for a gallon or 2 no?
Ok. I wouldnt want any car where a thicker diff fluid would ruin gears. I highly doubt that was it
Originally Posted by THE PHILLY JYNX View Post
Tom i used 2, 5mm shims on front pinion...zero wear at this point. 1 in the rear pinion.....and now the 45/10 is in...Just waiting on the rain!!!
Ok, ill check the pinion shim. Ah yes.....the rain thing. That always sucked
rallyebmx is offline
Old 05-18-2011, 04:15 PM
  #4352
I know when I built mine I shimed the diffs a little tight and they broke in perfect in about one or two tanks,but I have not had a chance to put a whole lot of time on my car yet. Only got about a gallon on my ride as of now.Also I use a very very thick grease I have been using for years.If I can remember what it is I will let folks know. This stuff is so tackey and stickey it really sticks to those gears lol.
BeefHead is offline
Old 05-18-2011, 05:04 PM
  #4353
Jaz240's Avatar
Trader Rating: 52 (100%+)
Any car with thicker oils will have faster gear wear. It's not my opinion it's just the laws of physics. The harder the gears slam into each other from a stand still the faster they wear out. The planetary gears won't be effected but ring and pinion as well as bell and spur will definitely.
Jaz240 is offline
Old 05-18-2011, 05:58 PM
  #4354
Trader Rating: 41 (98%+)
Are y'all using 2mm wheel hex on yalls setup
longdong1218 is offline
Old 05-18-2011, 06:28 PM
  #4355
killerkustoms's Avatar
Trader Rating: 16 (100%+)
I do and love it, works great on this car, eliminates traction roll.
killerkustoms is offline
Old 05-18-2011, 06:40 PM
  #4356
Front and rear
Old 05-18-2011, 09:07 PM
  #4357
Brian C's Avatar
Trader Rating: 30 (100%+)
I also use them front and rear. We had a very high bite indoor track for the winter and I switched to +1's in the front to get a little more steering but outdoors, always +2 for me.
Brian C is offline
Old 05-18-2011, 10:28 PM
  #4358
Thank y'all for the help. Has anybody tried 551 in there diffs yet??
Old 05-18-2011, 10:38 PM
  #4359
Originally Posted by frz83 View Post
Wow is Jerome Saetel for real running 3k,1k,1k? or can I just not read his writing,I would thing that it would be hard to drive
We are all running 2/1/1 in France and UK
very easy setup
try it you will love it
blade98000 is offline
Old 05-18-2011, 11:07 PM
  #4360
Originally Posted by Mark Erce View Post
Mark on a point to save your servos, the throttle link has been locked & will not move when you brake.
Bren Ralls is offline
Old 05-18-2011, 11:12 PM
  #4361
+1
I made a similar mistake and you'll find the radio tray bends like a banana when you brake.
Move the inside one much further in!
Flipfly is offline
Old 05-19-2011, 05:34 AM
  #4362
Coach Townsend's Avatar
Ok Mark I'll c ya. The wrap is pimped tho
Coach Townsend is offline
Old 05-19-2011, 06:27 AM
  #4363
VPProUSA's Avatar
Do not shim the diffs tight -shim them correctly so they are butter smooth all around. Then after 1 gallon rechech and reshim if needed. Running them tight will wear them out faster. If they are shimed right with no side to side movement, no in and out movement on the outdrives, and pinion shimed out to proper ring gear alignment, they will never strip out.
I posted how I shimmed my last car way back but since then, each roller I build is shimmed a little different because of tolerances, so I can't tell you how many shims and where to put them as each car will be a little different.
VPProUSA is offline
Old 05-19-2011, 07:43 AM
  #4364
VPProUSA's Avatar
Well my Agama Brothers and Sisters I finally got my car done and its ready to hit the track after I break her in! take a look at what I'm rockn here in the Midwest Bringin something new and fresh here in STL!!!
1. Arrow GTR .21 W/ VP-PRO RS-1(2060) PIPE
2. AIRTRONICS M11
3. SAVOX 1267/1268 SERVOS
4. LIPO 2000MAH RX PACK
5. VP-PRO AXEMAN & TURBO TRAX(UF) PREMOUNTS
6. BYRONS 30/9 FUEL
Sick Mark! Agama A8 / Arrow Racing / VP-Pro USA combo
I am happy to announce that Hobby Pro USA is now distributing the Arrow Racing GTR-21 .21 Nitro Engine here in the USA in addition to the Bullitt B-218 'OS Speed Style' Engine.
This Pro USA Edition will come with an O.S. P3 ultra hot glow plug, and a 7.0mm & 6.5mm carb restrictor instead of the 8 & 9mm reducers. They should be available June 8, 2011. MAP price is only $234.99
I have been using an Arrow-Racing GTR 21 in my Agama A8 buggy and truggy for the last 5 weeks. I have a stock one that runs just like a stock OS VZ-B V-spec and a modified one that runs even better then my O.S. VZ-B Speed II. I have tried the VP-Pro RS-2 exhaust pipe and an OS T-2060 pipe so far and both performed about the same. I have not got to try the RS-1 pipe on it yet. Let me know how it runs Mark.
The Arrow has way more compression and a tighter pinch then the OS vspec. I have 3/4 of a gallon through the modded one and it still has a mechanical pinch. Arrow says it takes 1.5 gallons (6 liters) to fully break in. On all my OS engines, it usually just takes 2 qts to break it in, which is why they only last 4-6 gallons before needing to be rebuilt. The Arrow is supposed to last 8-12 gallons when properly broken in and I can believe that seeing as how tight the engine is. With the parts being half the price and the engine lasting twice as long, it's like getting 3 GTR's for the price of 1 V-spec.
Now Agama USA racers have a choice of an engine similar to the most popular engine in the USA, the V-Spec at a lower price - The Arrow GTR-21. Or an engine similar to the high end OS XZ-B Speed but at a lower price - The Bullitt B-218.
VPProUSA is offline
Old 05-19-2011, 08:44 AM
  #4365
Hey Agama riders
I'm very often Jerome Sartel's mechanic and i confirm that we use thin oils in the diffs.
211 / 212 / 311
We used at the very begining 5/5/2 and the car was wheeling a lot and was not forgiven in the bumps.
Since we use thins oils, our cars are much more easier to drive . I personally love this setup. 211
Let's give a try and let us know
All the best
Sylvain
beuz is offline
