RB MODS 'ENGINE SLICK'
HAS ANYONE TRIED THIS STUFF?? REPORTS OF 28 GALLONS OUT OF A MOTOR ARE AMAZING!!
HERE'S THE LINK; http://rbmods.net/rbshop/index.php?t...product_id=131 |
WOW, seems too good to be true!
28 gallons?!?!?!?!?! So this stuff is like Slick .5 (instead of Slick 50). Just read the description....sounds interesting. Sounds liek it basically coats the sleeve in super slick stuff to essentially remove the friction which causes the wear. Sounds like a sound theory, but since we get lubrication from our fuel...I imagine this would need to be applied EVERY time the engine is run. Small price to pay for an engine that lasts that long?
Now I also noticed they just said 28 gallons....they didn't say 28 gallons with no parts replacements. So I'd need more info before I dumped it in my engine....It does look pretty promising though. |
Originally Posted by RC-ZOMBIE
(Post 6876232)
it is excellent stuff!!!
all of ricks stuff is top notch as well is he , he puts a lot of thought and time into his products before he puts his name on them !!! i would back his products in a heart beat :nod: i have used this stuff and it definitely slows wear by a large margin ;) |
slick man sick stuff slick....
Not a bad idea...
Hmmm... I wonder if it really is "Slick 50" ("PTFE," or "Polytetraflouroethelene..." a.k.a. "Teflon") suspended in oil, or something else. :confused:
Maybe zinc dialkyldithiophosphate? :confused: The first makes sense that you would NOT mix with the fuel (it could clog the carb.) The second makes more sense to me, as it helps prevent metal scuffing. That's a common additive in engine oil. I don't know why it wouldn't just be added to the fuel though. |
SNAKE OIL
Originally Posted by DOMIT
(Post 6876484)
Maybe zinc dialkyldithiophosphate? :confused: The first makes sense that you would NOT mix with the fuel (it could clog the carb.) The second makes more sense to me, as it helps prevent metal scuffing. That's a common additive in engine oil. I don't know why it wouldn't just be added to the fuel though. this new stuff goes straight into the engine and it definitely works :nod: |
Originally Posted by houston
(Post 6876615)
he used to have a fuel additive , you couldnt really run the engine on the track and expect any performance out of the engine with the stuff in the fuel . you had to make sure it was all out of the tank .
this new stuff goes straight into the engine and it definitely works :nod: this is the new stuff... the older stuff you had add to your fuel... and it works great... thisstuff you just a few drops to your engine and you are good... |
how long will a bottle last you?
