LIFE RX BATTERIES???
I just ordered new receiver packs for my cars and I am trying to find out a couple things that are not coming up in searches.
1. How often do you have to balance them?
2. can you balance them with an external lipo balancer (charger set on LIFE)
3. I have seen conflicting stories about whether or not you can run a life battery down to low.
Can some of you guys with experience running these batteries please clear this up for me?
Hi.
You can run them down to where the servos starts to slow down. At that point you not even close to the minimum voltage (4 volt), where the LiFe packs can be destroyed.
Cheers
Cheers
I run one and love it. I can run 3 quals and a 30 min main no problem. Last time after a full day of racing, the voltage was 6.85 and it's only 1450mah. I have yet to balance mine because I get a charge error when I try. For what they cost, I don't care if that decreases the life a little. You'll be happy with it for sure.
yes they are 2 cells 6.6V, mine peaks at 6.8
i think its agreat battery, its a 1700 hyperion, i do my setup(5-10)mintes, 3 qualifiers of 10 minutes + practice and a 45 minutes Amain and still has 30-40% in it. and i always charge it with the balancer, i dont know what's the balancer is for, i just do it , and yes you can use the Lipo balancer (2Cells)
cheers
Ali
cheers
Ali
a link guys for a good rx life battery.
thanks
thanks
Make using the right charging scheme. LiPo charge would be at a higher voltage 7.4 instead of 6.6
Where i can find a life rx battery and it will fit at kyosho radio box? also my charger write that charge lipo/life batteries but at the menu i see only lipo mode..i charge the battery at the lipo balance mode?
Correct. Some more details:
LiPo cells: 3,7 volt/cell
Max charge voltage: 4,2 volt/cell
LiPoFe: 3,3 volt/cell
Max charge voltage: 3,6 volt/cell
If I remember correct the Cobra Racing pack are 6,4 volt. Don't know how to charge them.
Cheers
I haven’t used my packs in a race yet (60 cm snow her in Denmark ) but I gave it some thoughts: For normal use (practice and qualification) I would charge them with the balancer every time. Before the main final the balancer shouldn’t be necessary for a short quick-charge.
Cheers
Cheers
hello guys,
too many questions
Kyosho packs are any HUMP style life battery: i use this one (Hyperion)
http://aircraft-world.com/shopexd.asp?id=6767
this is from LRP
http://www.lrp.cc/en/products/vtec-b...y-66v/details/
any battery with same dimensions should fit (its a tight fit though)
if your charger doesnt show life, you should see A123 when you search in the battery type. A123 and Life are the same.
charger should be on Life/A123 mode and the balancer is the same for lipo and life.
Losi LIfe Packs are sold by CobraRacing, he's in Australia but shipps worldwide, i'm ordering mine in few days.
cheers
Ali
too many questions
this is from LRP
cheers
Ali
