Ceramic bearing?
Ceramic bearing?
Hey all!
Im in the process of rebuilding a brand new clutch for my new engine. And I was thinking about putting 2x ceramic bearings instead of the regular ones (steel). I know that ceramic bearings have higher rpm capabilities and also that they reduce friction and vibration.
So with that in mind I was wondering if its really worth it to pay some xtra $$ for a set of clutch bearings, is this gonna help my engine in long term?
Any tips, opinions or comments would be apreciated!
Zuma
Zuma
Unless your a pro you won't see any difference, except the cost.
i would remmond the tko, high rpm clutch bearings they are awsome .
Are they really gonna last longer than a pair steel bearings?
I disagree!
Ceramic bearings rock for the clutch, they dont heat up nearly as much, and therfore don't fail like standard steel bearings. I installed a set of ceramic bearings for a big meet, and ran the same set every other weekend for 4 months !! I only changed them for another set of ceramics because i thought i should.
Do it, you wont regret the investment.
i think so i ran plain steel clutch bearings, and they failed on me kind of quick
and the tko high rpm clutch bearing .is ,still smooth after a gallon of fuel.
tko clutch bearings all the way,
i have also seen standard steel clutch bearings cause radio noise.
If you need bearings...........
http://tkocompetitiondev.com/
http://www.readyrollers.com/main.sc
Both of these vendors will treat you right!
As soon as a clutch bell with ceramics hits the chassis from a hard nose first landing they will be done!
TKO radial thrust "new special" clutch bearings all the way!!
http://trackstarrc.com/trackstar/ind...mart&Itemid=64
Available in pairs and 10 packs.
Alright, so far you guys are just giving me pros about using ceramic bearings so with that I think im gonna try it. I just hope I wont have to change them every 1/2 gallon.
do u mean if the clutchbell gets loose, ceramics bearing will be done?
oh i have used ceramic clutch bearings, before i guess i been lucky with the ladings. have u tried the tko high rpm ,clutch bell bearing there also man .
and i tried losi hd clutch bearing and ,that went bad and a losi regular steel bearing and that dint last long .
