-   Nitro Off-Road (https://www.rctech.net/forum/nitro-off-road-130/)
-   -   ninja jx ,shim 30% ? (https://www.rctech.net/forum/nitro-off-road/354164-ninja-jx-shim-30%25.html)
Gen 12-23-2009 12:54 AM
just got me new donk and want to know is it really necessary to install shim q
when running 30% nitro ,,,i want to keep max power cause im using in truggy or is it better to use ? ,is life greatly shortened by not using ?,,also do os venturis fit carby ?,,as this is a os engine
jmaxey51 12-23-2009 01:32 AM
i would put one on because it will last a good bit longer but a ninja has plenty of power even with the shim. we run a JPX 21 in our jammin truggy that everyone says is heavy and we just run 20%. i would get the shim and run 30% and it will have plenty of power.
jpalessi 12-23-2009 08:44 AM
The engine comes stock shimmed for 30%. do not add the extra shim. yes os stacks will fit... i like the 8mm
s porter 12-23-2009 12:13 PM
Run the extra (2 total) copper shim for breakin...Remove it after the engine loses pinch.
romax 12-23-2009 03:12 PM
Delete wrong post , sorry
jrwoodchuck 12-23-2009 05:34 PM
+1
I did this, and I have no issues.
