-   Nitro Off-Road (https://www.rctech.net/forum/nitro-off-road-130/)
-   -   tire foam qustion (https://www.rctech.net/forum/nitro-off-road/352918-tire-foam-qustion.html)
bigguyrc8 12-18-2009 05:53 AM
tire foam qustion
im not sure what type of foam to put in my tires,i am going to run a m3 proline holeshot,and caliber,should i use a soft foam or something else,i thought if u use and need a soft compond tire than use a soft foam.let me know thanks everyone.
RAlmeida 12-18-2009 06:17 AM
You opened a big can of worms, foams are track and setup dependent.
m .02c
bigguyrc8 12-18-2009 06:24 AM
there has to be a general rule,a starting point.
JQ 12-18-2009 06:41 AM
Stock foam will always work well.
Hard foam can give more forward bite and cornerspeed, but can be worse on rough tracks, or high traction, as it is less forgiving and can make the car flip over easier.
bigguyrc8 12-18-2009 06:50 AM
so u think the gray proline inserts are fine to start,or the ofna yellow which is a med. foam.
Integra 12-18-2009 07:50 AM
DONT use the grey Craptastic inserts...imo they are way way worst then a open cell standard foam(which i like very much so in certain conditions)
JQ 12-18-2009 08:22 AM
Yes the grey foam the tyres come with is fine. That foam won the last 2 world championships and European championships so if your car doesnt handle well, its not because of the foam.
To know the difference you can then mount your next set of tyres up with the EVO foam, or the new hard blue insert.
Integra 12-18-2009 10:50 AM
the grey's tear like no tomorrow....there's a reason they are being slowly discontinued.....worlds winner or Not....you think they actually deal with a torn Foam...LoL they toss the tire and slap on a new one.
AndrewClaycomb 12-18-2009 12:48 PM
After every race.
mblgjr 12-18-2009 01:04 PM
The std. PL gray foams are a fine starting point.
Maybe I'm lucky; but they generally last the *best* useable life of the tread.
I've never had one break or tear; though the balance is pretty crappy. I still like the gray foams for most outdoor tracks unless you're on super blue groove.
The Ofna inserts are a little narrow (yes, the PL profile yellow Ofnas) so I'm not a huge fan of 'em, but they're ok.
The new PL black EVO foams will probably work fine all around as well. I liked the blue ones they just released; but have heard slightly better comments about the black ones.
JQ 12-18-2009 01:07 PM
the PL grey foam used to tear 3 years ago, and it happened to me twice. They dont tear anymore unless you get them wet.
DPowers 12-18-2009 01:14 PM
i like the ofna yellow foams are the HB foams the best i have had the aka foams tear along with the pro line grey foams i havent tried the new blues one yet but i will stick with the ones that work for me just mt 2 cents.
Integra 12-18-2009 04:01 PM
I have experienced differently...and so have Many others.
Integra 12-18-2009 04:02 PM
How did you tear an AKA foam ? was there excessive glue on the inside ? was it a premount ?
DPowers 12-18-2009 04:07 PM
yeah it was a premount i and i couldnt believe it myself but it happend last week.
