idling issues!
Hi i have a SH.21 engine and i have an idling problem. It is never consistant. i can have it tuned sweet if i keep the revs going a bit but then i can go for a run it run good come back. take off again it it will just hit high revs and wont go down for a long time and it just wont stay at idle.
What could be the problem all input needed Cheers |
Originally Posted by yuppi1
(Post 6666816)
What could be the problem all input needed Cheers It's also possible you have an air leak in the tank that only hits once the fuel is below a certain level. |
Deffinately sounds like you are too lean on the bottom.
could be too rich on the bottom too, over compensated with a big gap. once it gets up to temps it won't come down for a bit. also check for an air leak.
