rb s3 rod in a nova n21bf limited ???
Hi I have a new rb s3 conrod and wanted to know if it will work in my nova n21bf limited? thanks.
I don't think so but I could be wrong.
Nova rod lesson:
Nearly all Nova based .21 motors (including RB S, C and WS motors) use the R series rod, R1 through R7. They all have the same dimensions, higher numbers are just improved versions.
The exceptions:
1. I believe short stroke motors use a different rod and I believe the BF21 is one of those, not sure though as I have never had one of their short stroke versions.
2. Smaller crank pin motors. These are mainly onroad motors though I think they did try this on one of the high end offroad motors too. This would be the Collari edition and Cordoba motors (4.5mm crank pin) that use C series rods and the 353 (4mm crank pin) that uses a P series rod. These are the same length as the R rods, they just have a smaller lower rod bushing for the smaller crank pins.
Nova rod lesson:
The exceptions:
Up until 2 years ago, RB engines had different crank pin sizes than most all others. I think it was smaller to reduce bearing surface speed. I don't know whether or not they changed, 2 years ago was the last time I heard it mentioned.
bf 21 uses a r7
