heating a motor for break in?
what are a few options to heat up a motor during break in before starting it?
If you're some where in socal Harbor Freight tools has a good heat gun
Any tips for avoiding the carb while heating the head and case?
Don't point the heat gun at the carb.:p:lol:
You could put a piece of cardboard between the head and carb. |
Hot pad
Originally Posted by makaluch
(Post 6458344)
will a hair drier get it hot enough as a temp fix?
I've seen hair driers get motors to 150-180. Not hot enough. Spend the $10-20$ and get the heat gun. You've spent enough on buying a motor to not spend a tiny bit more and have an engine that will last.
hmmm
no need to heat a motor. It will warm up all on it's own. Unless it wont start. I don't use calipers or temp guns either, and I don't change setups every day. Still win races and get 10 gallons from my motors without worrying about runtime. Huge box of tires? nope. I do clean my car really well.
wise words
Originally Posted by merdith6
(Post 6470864)
by the way how u cleaning the car? |
I genereally heat mine up until break in is done.. then if possible for a few more tanks. But by that time im running it down the track.. so dont have power to use the heat gun.. But Heating a engine on break in makes it x2 as easy to do that.. cold.. years back breaking my 1st Go engine.. Toke me over a hour to start it. because of the pinch... but I dont think many do it that way anymore.. or did lol.. but I didnt know any better..
(Post 6470864)
lots of overrated techniques out there |
Originally Posted by gas-man
(Post 6458441)
I use a hairdryer to pre-heat the engine to at least 150F, and continue to do that until there is little to no chance of the piston sticking at TDC when cold. That could take up to a gallon of fuel, depending on the engine.
I heat the engine head and block when breaking in the engine and until the metal pinch is gone. I also use a heat gun when the weather is cold. I race in a winter series and in the morning it's usually in the 30's engines don't like to start when it's that cold outside.
