monster gt with a o.s. v-spec
ok i just purchased a monster gt roller, i have a o.s. v-spec21 i can put in it i there anything else i would need to be able to race it
any setups would be great thanks in advance |
You will need a way to start the engine..I dont think you can use a bumpstart engine in a MGT
Maximo is correct. I don't know if anything exists, maybe look at Tiger Drive? and see if they have a back plate that would work for it, so you can use a roto start or drill.
we custom fit a v spec into a t maxx and made a custom header that routed the the exsoust out the back of the truck with a tuned pipe (something like a revo)
and made a custom chassis and used one of those airplane type starters with a rubber wheel and we were able to get at it from the pipe side were we cut the chassis to allow it. |
As far as I'm aware, there is no rotostart, backplate, or pullstart that will work with the V-Spec, they are bump-only engines. Or more to the point, you could get a backplate that would fit but the crankshaft/conrod in stock V-Specs has no pin-hole or slot to put in an alternative start option without changing out the crankshaft to something else.
thanks for the replies everyone i also have an lrp30 pull start and a osi engine pull start so i will be ok
im looking for setups like clutchbell, spur, pr other setups to make it ready to race |
its an mgt the thing is going to break as soon as you get to the track let alone put more power to it.
Originally Posted by jqtopa
(Post 6442080)
