Help my throttle servo hums when i turn on the truggy
Hey guys when I turn on my truggy the throttle servo hums? Is that ok or should I reset the he horn? I don't know if I should move the trim on the radio or reset the horn thanks:weird:
Is this hum only at full-lock; or when you're turned 20% does it hum?
Originally Posted by GASMAN123
(Post 6382419)
Here is a link to the manual http://aedownloads.com/downloads/man...tft_manual.pdf |
help my throttle servo hums when i turn it on
I turn on my radio then I turn on the truggy that's when I hear the humming from the throttle
(Post 6382419)
Thanks guys ill take a look at when I get home and if I have questions ill check back with you guys thanks again for helping out the newb
Ok well I've only ran the servo 4 times and its going out already its an ace 1015 who do I sent it to ? I've tried to call Thunder Tiger but no help ? Any suggestions? I paid 110 bucks for this ? Help !
(Post 6391175)
Digi servo's can and quite often have a hum to them...no major cause for alarm. You just want to make sure its not because of binding issues.
My Hitec servos make all kinds of noise but there isnt anything wrong with them. Digital servos often make noise because the little processor inside is constantly trying to adjust and find center. If it still works fine then I dont think you should be too alarmed.
What about if its twitching back and forth and I'm not even touching the radio ? Is that normal for digital servos ? Thanks again guys next weekend we start racing and I'm trying to get ready
(Post 6391723)
Could it be one of those Digital Sevo w/an Analog controller type problem?
I've heard some strange stuff happens when you mix & match the two.... |
On some spektrum radios that I have seen if the radio is to close to the car sometimes it will make the servos glitch I have seen it happen on a few radios my old m11 with a spektrum module did every now and then if you're servo is humming chances are it's not centered move you trim a little both ways to see if it stops you might need to readjust the linkages to get it centered
Twitching is bad. Its probably got a bad gear or the case may be broken inside where the little pin that the gears ride on goes in. That is a problem Ive heard of before. I had a 1313 that would do that on steering. I sent it back and they sent me a new one.
Spektrum will cause glitching if you have the RX and TX within about 3ft of each other but thats a glitch where the servo would normally just do it once in one direction and then stop rather than bouncing back and forth. |
