Losi 8ight 2.0B Servo Saver Change Advice
Guys,
Ive shot 2 servos in the last week without crashing. I need to make the servo save change ASAP, but im unsure as to what i need to change exactly.
Is it the post, spring and plastics from the 1.0, just the spring, or just the plastics?
Steve
Steve
End point?
How do you have your end points adjusted? That might be a big part of the problem.
2% below full lock
You need the 1.0 buggy plastics and 1.0 truggy spring. Or the kit is LOSA4406 that has it all together.
that kit is the 2.0 plastics only.
If its the 1.0 plastics and 1.0T spring i can get those ordered up asap
the same thing?
Unless that part code is the same for a different item in the states, its not the 1.0 plastics and 1.0T spring here in the UK.
That part code relates to the 2.0 plastics. Does not contain the 1.0 or 1.0t spring.
