how many gallons on your motor ???
just wanna see how many gallons every one is getting on there motors
what kind of motor, pipe,fuel,comments
im running a RB C6 T7 with 2045 pipe,92mm header on byrons
so far i have about 9-10 gallons on the motor never opened everything original
the engine has plenty of power,never flames out holds a tune well mostly high side adjustments..
im hoping to 15 gallons on the original piston,rod,sleeve...after that ill change the p/s/r
take a look im the black truck in the video
part 1 http://www.youtube.com/watch?v=QUIhhx5oElM
part 2 http://www.youtube.com/watch?v=BDS1T35qzy8
R/C Tech Elite Member
I got an Axe Rossi Cobra .21 running a 053 pipe and i have a round 5 Gallons on it and the pinch is GREAT i hope to get 10 Gallons out of the motor. Only thing done to the motor was a Front Bearing at the 5 Gallon mark
I have been running Bryons 20% but now i run Cold Fusion 30%
My 5k lost a rod at gallon 9.
Ran a jp3 and then 086 and went through every kind of fuel sold locally and it had an idiot as a tuner Not bad I say
15 gallons? Dude, you should check the bearings atleast every 2 gallons at the most. You must not be racing hard, to get that kind of mileage out of your motor, when you arent checking the internals out.
I actually just hit 10 gallons with my VZB today, ceramic bearings, original p/s/r. It still has great compression and runs perfect!! I can't wait till my worlds edition comes in. I hear a lot of guys are cracking the case and the front bearing on the VZB II is bad. Anyone ever have that issue? Just rather get a heads up and just place it before i even run it.
Hi, i wanna know how break-in my engine 421B best?
novarossi n21bf w/ eb mods pipe and header 12 min runtime ran in the 270's 17 gals of 30% nitro juice. couldnt ask for anything more out of 150 motor have two new ones in the box running a nova 21-4 now 2 gals in
osspeed....goin on 7-8 gallons with only a mainbearing change at 2.
still runin strong with a ebmods 2041.i tear it down about very gallon these days to check on things..im gonna rebuild it soon
I dont keep any engine over 5-6 gallons
its raced hard every week but i take care of the motor its raced but not beaten on. on the bearings hwen i looked at them they looked fine on the milage i get about 9-10.5 min on a tank but it bepends what temp im running never run more the 225-240 any more then thank i pull it off right away
