Originally Posted by petevette
(Post 7481317)
Anyone know what kind of restrictors fit on the Jammin? I searched Amain but didn't see any restrictors specific for Jammin.
Originally Posted by Uptown
(Post 7481553)
I have a 7mm aluminum one. I just through out the original tags. I believe it came from ofna if that helps
Thanks. |
The Jammin is a Picco engine. Ofna sells Picco restrictors down to 7mm.
it comes with a 7mm doesn't it?
Originally Posted by bigemike
(Post 7326564)
On nitro house it says the 51013. Replaces 51006
http://www.nitrohouse.com/catalog/pr...ducts_id=22354 It's only $6 at nitrohouse? |
reply
there is a new mob out of hong kong selling restrictors from 6mm - 9mm for the picco engines now on ebay
Need help with plugs
Hey guys - trying to make sure I grab the right plugs for this engine but I'm a little confused.
From PICCO's site: TURBO COLD GLOW-PLUGS •P5TC hot filament •P6TC medium filament •P7TC cold filament TURBO HOT GLOW-PLUGS •P5TH hot filament •P6TH medium filament •P7TH cold filament Maximo's feedback - "we generally run the OFNA Picco Med turbo ( P6TH)" OFN51005 seems to be a P6TC, which I guess is different? OFN51006 supposedly comes in the box - which on amain comes up as a different plug in the picture, and is backorder. But on another site it looks like this http://myatomic.com/catalog/viewsku?...um_glow_plug_1 On here I read that supposedly the 51013 replaces 51006, but the picture so this on nitrohouse show a "TL"? racing plug that is $6, doesn't look like a Picco... I guess the 51006 is discontinued? In any case - I'm confused! Help! I just want to grab a couple of the right plugs.... |
need help what are the front and rear bearing sizes and does any one know if a 2035 works good with this motor
thanks for the help |
Originally Posted by keithw11
(Post 7557888)
Bearings are the same size as the OS Vspec.
maximo what is with the cheaper picco plugs will they work good or does anyone know? Thanks
Originally Posted by manson98
(Post 7572001)
reply
Well guys is there any update on the new plugs in the picco 21 plus engine, how did they go, im in the market for some hot turbo plugs myself, medium just doesnt give what i want and the 51006 was the bee's knees but im out of those and really need to find plugs now
I am out of the 51006 plugs as well so i opted to run os p-4 med/hotplug this weekend & it actually ran good . Didn't seem to have quite as much bottom power but tune was consistent & made good overall power . P-4 is med/hot so i would think the p-3 would be a good substitute . I know they prob. won't last as long but that's all i have at the moment .
Does anyone know the factory needle settings? I lost my paper that had it on it..
Maximo, What are some symptoms that will happen to the jammin engine when the crank pin bearing starts to go?
Originally Posted by Quad Racer 34
(Post 7605806)
I usually blow the rods before the bearings LOL ! If a bearing is going the tuning can become odd, will start blowing plugs and flaming out....likely even more symptoms then that even, but that is all i can think of |
oh no. It went through a plug today that my other engine has lasted 3 gallons on already :(
I'll give it another shot after the weekend with a fresh plug. Thanks for the response. |
reply
Well still no feed back on running the new ofna turbo plugs in the engines, any one what so ever, I dont want to go down the o.s plug road but need plugs for these engines a.s.a.p.
Clockworks have you tryed the new 510013 t4 in a picco/jammin engine, what where your thoughts on them ??? |
Where can you buy a rod for this engine? I looked on amain and they didn't have one. Can someone help me out?
Hi guys, my JPX flamed out three times last weekend in the exact same place on the track - on the landing of a big jump. This just started recently. What could cause flameouts on hard landings?
(Post 8067320)
(Post 8067320)
I would look into the flywheel and chassis clearance .
I am not on power and I don't think it is rocks. I don't see any scraping of any kind where the flywheel meets the chassis. Can less then ideal compression cause this? The engine has been a champ, but it has some time on it. The compression feels border line when it is cold. Some folks say the compression is still okay, but others say the compression is low. I think the engine may just be tired.
What do you guys think, can it be a compression thing? Thanks!!!!! |
i bet the flywheel is hitting the dirt, my dad and i had the same problem with our JPX over one big jump on the track so we switched engines and still had the problem and realized it was just hitting the flywheel, if we landed with some throttle it would stay running. so its probably that.
(Post 8068668)
Originally Posted by jmaxey51
(Post 8068725)
Brian |
Good input guys. The first two times it happened were during the 5 min qualifiers. I raised the idle a click before the 20 min main an attempt to eliminate a low idle setting. Well 10 minutes into the main and all was good. I thought I was golden. Then with 4 minutes to go it flamed out again.
I am going to try to keep the back of the car from contacting the ground first by bringing down my front end right before landing. If the flameout is caused by clay/rocks hitting the flywheel bringing down the front end should help minimize the risk of it happening again. I am starting to think that the hard landings may have been with the chassis flat or even landing the back of the car first. Lets see what happens this weekend. Thanks guys! |
(Post 8068668)
