OS .21 Break in needle settings?
(About) How many turns out should the low speed and high speed be for my os 21vzb during a heat cycle break in?
Originally Posted by Muggydude
(Post 6261640)
I break in all of my OS engines at factory settings. Sometimes you will need to lean the top end and or bottom end a few hours to actually get it to stay running, but other than that, factory settings. Don't lean it if it will run at factory. IMO the more fuel, the better for break in. Keep temps at around 200* F. If needed use a piece of tin foil and a heat gun. Always preheat close to 200* before starting.:nod:
