97t in a V-spec?
I've only used OS plugs in my V-specs and I read someware that the 97t/77t has a different "taper" and won't seal correctly in the V-spec. Did I read this wrong someware? I just want to know if it will work.
yes, I tried a search.. thanks. |
Originally Posted by jrwoodchuck
(Post 6191807)
Thanks for asking the question, Doug. I was wondering the same thing.
i have an os vspec and the odonnell work fine but im going back with os plugs only.
Originally Posted by GOTCHA007
(Post 6191870)
conflicting information but I was told that Odonnell plugs that are made for the OS taper have OS in the part number..Just FYI and only what I heard, but I have seen some OD plugs with OS in the part number
I use both. P3 and 97t. they both run great.
and this is purely my "feel" 97t/77t seems to have better bottom, while P3 gives better top. |
P3 will be easier to tune, which is why most peeps run them
97t will allow for a much finer tune, and will run better because of it |
(Post 6191920)
why?
Originally Posted by imaxx21
(Post 6195604)
oh yeah, by the way the plug i was using this past weekend was an odonnell 99t which is their on road plug and still won !!!:nod:
+1
my tuning skill is slowly getting better. still not good enough to touch the mid needle. OS plugs seem to run about 20degrees cooler too though. life seems to be about same. so. i'll take $5 OD plugs over $10 OS plugs anyday. |
