What is this.....
1 Attachment(s)
The description from amain (where I got the picture says):
(1) Base Mount (1) Set of top blocks (8) 5-40 x 1/2" Alloy Allen Head Cap Screws (4) M3 lock washers (used with screws that hold the top blocks to base) It mentions nothing of the piece I circled. Thanks. |
I have that mount. I did not have that piece.
it replaces yor plastic fuel tank mount. it goes at the end of the extended side of the lower plate
Originally Posted by rallyebmx
(Post 6084976)
Originally Posted by crotty777
(Post 6084980)
Thanks. |
Originally Posted by Garet Jax
(Post 6178064)
Well I finally went to install the mount and now I know what you mean. I bought the mount used and the piece did not come with it. Do you happen to know the part # and/or where or not I can buy it used?
Thanks. Call up Jim at Kingheads and he will take care of you....I Think they might have it listed as a single item on their site but not too sure.
(Post 6084976)
then your tank would not be supported on 1 end...or you cut or modified the stock post to make it work...its not possible to run That particular mount without that piece....you must have bought the non extended version. :nod: |
