Lucky 7 Engine Sealant >
Old 07-12-2009, 10:55 PM
Trader Rating: 7 (89%+)
Default Lucky 7 Engine Sealant
Hi guys, is this engine sealant a permanent one? I havent used it cause i want to make sure i can still remove my carb if i want to. Thanks
oggietiu is offline
Old 07-12-2009, 11:01 PM
houston's Avatar
Trader Rating: 96 (100%+)
this stuff is identical to the old air seal brand product and is 1,000 times better than any rtv silicone product put out by other companies .
it can be removed and cleaned then reapplied with no issues .
if there is a must to seal the engine , do it from the outside
houston is offline
Old 07-12-2009, 11:08 PM
okey thanks. I plan on using it on my Vspec carb to seal it properly. Where exactly would i apply it? Will i insert the carb to the crank case first then seal or apply it around where the oring goes? with or without oring?
oggietiu is offline
Old 07-13-2009, 12:29 AM
FrankBlack's Avatar
FrankBlack is offline
Old 07-13-2009, 12:45 AM
oh no! I kinda put lucky 7 to where the oring goes then inserted the carb then seal again from the outside. Will I still be able to remove the carb?
oggietiu is offline
Old 07-13-2009, 12:51 AM
FrankBlack's Avatar
Should be able too, take the carb back out and remove all the sealant.
Old 07-13-2009, 01:49 AM
losi_racer's Avatar
Trader Rating: 25 (100%+)
yes, some people say to seal on the outside, but most people say and do to apply then install. this is what i do, i dont have air leaks or anything else, just my .02 cents
losi_racer is offline
Old 07-13-2009, 06:32 AM
Toiffel's Avatar
Trader Rating: 52 (100%+)
Default Got a glow plug???
Get Joey, u got some plugs????.......................
Toiffel is offline
Old 07-13-2009, 08:57 AM
jpalessi's Avatar
Trader Rating: 55 (100%+)
Lucky7 engine sealant should be used like a coating, not a gasket.
(external use only)
I seal around the carb base, the pinch bolt ends, and the HSN assembly.
u stay outta my pit-box!
jpalessi is offline
Old 07-13-2009, 11:27 AM
R/C Tech Elite Member
JayL's Avatar
jpalessi: any good pics of good use of lucky7 on an actual engine?
JayL is offline
Old 07-13-2009, 01:10 PM
jpalessi's Avatar
sorry for the bury photos...
Attached Thumbnails Lucky 7 Engine Sealant-img_0192.jpg   Lucky 7 Engine Sealant-img_0194.jpg
jpalessi is offline
Old 07-13-2009, 01:21 PM
Toiffel's Avatar
holy chit batman, those pics are very bury........lol....u might be able to tune an engine, but taking pics, now that's a different story....LMAO
Toiffel is offline
Old 07-13-2009, 01:56 PM
jpalessi's Avatar
The focus on my iphone sucks..
jpalessi is offline
Old 07-13-2009, 04:27 PM
FrankBlack's Avatar
Attached Thumbnails Lucky 7 Engine Sealant-picture-003.jpg   Lucky 7 Engine Sealant-picture-004.jpg
Old 07-13-2009, 05:06 PM
jpalessi's Avatar
thx dunn!
I put mine on a little heavier because when it dries it shrinks down a lot.
I really just gotta do a "how to video" and put it on the site.
jpalessi is offline
