NEED HELP WITH CHOOSING LIPO BATTERYS FOR MY RECIEVER AND STARTER BOX AND A CHARGER
WHAT IS A GOOD BATTERY AND CHARGER SETUP FOR MY MBX6. AND FOR MY STARTER BOX
Originally Posted by halfman
(Post 6049707)
as for a starter box a 14.4V if you look on amain they have several ones geared just for the starter box I use the Losi lipos and have one comman sense lipo -Practice pack |
THE MBX6 ONLY TAKES STICK PACKS. SO THE HIGHEST I CAN GET IS A 1700MAH AND IT ONLY LASTS ME 30 MIN MAX. THE ACE 1015 DRAWS MORE THAN A NORMAL SERVO.
venom pro charger!!! I like mine!
You will have others tell you that the chepo lipos are just fine. I have seen the destruction a faulty lipo can do so I would rather stick with the name brands. I sleep better at night knowing that I paid for QC.
For a charger there is none better than the hyperion series. If you are patient then the 606 will work just fine. If you need to charge 2 batteries at the same time then the 610 duo is the way to go but you will also need a power supply. I would reccomend getting 2 hyperion 606 chargers. These chargers will also balance charge which is very important to lipo life. Just make sure you also purchase the correct balance port adapter so you can balance charge. For battery packs the receiver battery will take any lipo stick pack will work look for 2000+ mah and you will be fine. I know protek has a new stick type pack that will also work in the M11 transmitter. For the starter box you want a 4s 14.8v 2000+mah that is at least 15c, (20c is better). Personally I use the hyperion 606 and a losi 4s 2200 lipo for the starter box. The 4s will last a 2 day event with no prob. Here are are some links to these products. I hope this helps. Hyperion 606 Protek stick pack Losi 4s 14.8v starter box battery Protek 14.8 starter box battery HT Batteries 14.8 starter box battery |
Originally Posted by Frank L
(Post 6049917)
(Post 6049786)
What? ? ? somethings wrong - In my buggy I run both ace servos 2 - 1015 and run a comman sense lipo 1500mah an it last though moreing warmup and 3 qaulifers........ by prokek make one 2100mah - http://www.amainhobbies.com/product_...mAh-No-Balance |
i meant my 1500mah nicd battery
(Post 6050515)
yes i am. i was saying what i am using right now 1500mah nicd will only last 30 mins. i want a lipo that will last a lot longer.
(Post 6051098)
I left my car on overnight last week and I showed the LiPo battery to your dad. It's puffed and ruined. $40 gone. I'm invested in LiPo and I'll stick with it. But, consider that LiPo is an additional and more expensive responsibility. |
Whats up halfman? Like mark said, if you are only getting 30 mins out of a 1500 nicd or even nimh pack the battery has a dead cell or something is wrong. I took the lipo leap for several reasons. My transmitter for example, it is lighter and I get way more runtime than with larger nimh batteries. The 3pk eats batteries. On my buggy the same results, can shed and ounce or 2 from the car depending on which pack I use, more runtime, boost in speed and torque for my servos because I choose to run unregulated. My starter box. I have a single 4s 4000 mah lipo, lighter than 2 stick packs for sure, and way stronger. I find that I dont have to keep up charging batteries as much which gives me more time on the track and behind the wheel. Just get a good charger, preferably a balance charger and you will be good. The biggest mistakes on a lipo is running it to low or over charging it. Once again avoid this and you should be fine. I run the apogee packs in my mugen. They make good batteries and happen to have a real good price on a stick pack for the car. I have put a link to the pack I use.
http://pfmdistribution.com/secure/sh...d=247&catid=66 |
