LITTLE HELP !!!!  with my losi 8ight 2.0 >
Old 07-06-2009, 05:55 PM
  #16
Trader Rating: 29 (100%+)
whoever said you put the throttle servo in reverse is wrong. its your clutch like everyone else is saying.
slayyer is offline
Old 07-06-2009, 08:13 PM
  #17
yea im not saying its not the clutch im gonna pull it out and check it ,but if you change it to reverse does the car still roll freely or not ?
shaun0_18 is offline
Old 07-06-2009, 08:33 PM
  #18
jhipps835's Avatar
Trader Rating: 13 (88%+)
YES...
Now check that clutch
jhipps835 is offline
Old 07-07-2009, 12:04 AM
  #19
yea ive pulled engine out and now what haha. ive also changed the throttle servo from the standard z650m to a hitec hs-5625mg is this a ok swap or not ?
Old 07-07-2009, 12:13 AM
  #20
alright u have the engine out.. now get a 2mm hex driver and take the screw holding the clutch bell on off. then the clutch will be exposed and check if there is anything that looks wrong with it. but yea that servo is good! better than stock!
slayyer is offline
Old 07-07-2009, 01:36 AM
  #21
losi_racer's Avatar
Trader Rating: 25 (100%+)
losi is standard my friend, its 5/64th
losi_racer is offline
Old 07-07-2009, 02:24 AM
  #22
dishsoap's Avatar
Just pull the dang clutch bell off already and there is a good chance your problem will be solved after you file down your shoes and put them back together. I am starting to think that during break in he didnt allow the tires to spin freely while getting on the throttle.
Did you happen to put it up against a wall during break in and pressed the throttle so it wouldnt go anywhere or did you hold down the buggy while giving it gas so that it wouldnt take off not allowing the wheels to turn?
Either that or the shoes were bad to begin with and had burs on them creating them to heat up and stick.
dishsoap is offline
Old 07-07-2009, 02:54 AM
  #23
car was perfectly fine until it took off by itself and then crashed into a post. ive only had 3 tanks of fuel through it
Old 07-07-2009, 02:58 AM
  #24
dishsoap's Avatar
With no electronics on when you try to roll it on the ground what happens. Does it feel like its stuck and the tires do not want to move freely. If so its your clutch.
Have you pulled the bell off yet? Please dude just do it. Its really easy to put it back together.
dishsoap is offline
Old 07-07-2009, 04:23 AM
  #25
ive only got engine out for now. tomorrow i will give the rest a go
Old 07-07-2009, 05:37 AM
  #26
token's Avatar
OMG WTF - just freaking do it and stop chatting about it.
Also if it just "took off" make sure your rebind the radio. Just for good measure change the clutch bearings too, since it take you 48 hrs to take off the engine and another 48 to take off the bell. Oh get some new springs.
The springs is what keeps the shoes down do if they are stuck the springs are shot.
Sorry but a clutch will not get stuck and you wont have to replace things,
something in the clutch setup failed.
+1 5/64th
token is offline
Old 07-07-2009, 06:11 AM
  #27
DOMIT's Avatar
Location: Fort Worth, Texas, USA, North America, Earth, Solar System, Milky Way Galaxy, Universe
Not on the clutch bell. ENGINES have metric threaded crankshafts. Doesn't matter what engine. 5/64 may be essentially the same... but the bolt in the end of the crankshaft is metric.
DOMIT is offline
Old 07-07-2009, 06:14 AM
  #28
Frank L's Avatar
Trader Rating: 148 (100%+)
The engine shafts are metric though even losi engines. The usual countersunk screw is a 2mm, I use a cap head screw that is 2.5mm. Pulling he clutch is not that big of a deal you should do t before every long main anyway just to make sure your cluch will hold up.
Frank L is offline
Old 07-07-2009, 08:22 AM
  #29
the screw that holds the clutch bell on is metric losi racer. Its a 3 mm screw that takes a 2mm to get it off.
roadracer43 is offline
Old 07-07-2009, 09:07 AM
  #30
my point exactly. trust me i know its a 2mm. ive taken my engine off to clean PLENTY of times!
slayyer is offline
