Need some 1/8 tire help. >
Old 07-02-2009, 12:45 PM
j.d.roost's Avatar
Trader Rating: 32 (100%+)
Default Need some 1/8 tire help.
I have been running Crimes (m2/m3) for two years now and I would like to try a different tire. Our track is hard pack with some loam on top (dusty) when it gets dry but the dirt will get loose when wet. There is also some small surface rocks embedded in the dirt that will wear out the m3's quickly.
The Crimes work great just want to try another brand/tire. I did use Goosebumps last year but they only lasted 4 races (heats mains).I can't afford to make a spending "error" here so let me know what feels like a crime fighter but gives the car a "little" more rotation without loosing fwd bite.
Jim
j.d.roost is offline
Old 07-02-2009, 12:56 PM
Scottmisfits's Avatar
Try the J Concepts Hitmen. From the sounds of it, the goosebumps aren't designed for your track conditions. They are for very loose powder type tracks that have have pack underneath. Think SilverState.
I'd go with the Yellow compound. Grip like an M3 with wear of an M2.
Scottmisfits is offline
Old 07-02-2009, 01:38 PM
j.d.roost's Avatar
Funny. I got to try out a set of those for a heat this year (friends) and they ran just lake a crime. So much so that my lap time were just about identical (sans crashes). Yep they work good too. Looking for a different tread setup I guess. How are the aka city blocks?
Old 07-02-2009, 01:51 PM
PTP Racing's Avatar
Soft City Blocks have been great for me. Ive run them in every race Ive run this year at 5 different tracks. They are absolutely worth trying.
PTP Racing is offline
Old 07-02-2009, 02:01 PM
Racecrafter's Avatar
Trader Rating: 25 (96%+)
AKA's Soft City Blocks or Cross Braces would be the ticket for you.
Racecrafter is offline
Old 07-02-2009, 02:49 PM
bcr500's Avatar
Trader Rating: 34 (100%+)
panther kd2s sound like a good fit for you in my opinion. I tried them the other day on a track were crime fighters work good wich sounds somthing like your track and the panther kd2s hooked up alot better.
bcr500 is offline
Old 07-02-2009, 03:50 PM
Gearhead racer's Avatar
AKA Cross Braces Medium+1
Gearhead racer is offline
Old 07-02-2009, 04:48 PM
+1 on K2's in either soft or med-soft.
Stealth_RT is offline
Old 07-02-2009, 04:58 PM
I tried the KD2s and for some reason they wore FAST. In about 10 runs they were bald. I would also contribute to those tires as being too hard and causing excess wheelspin.
Chris__RC is offline
Old 07-02-2009, 05:04 PM
R/C Tech Elite Member
XXXDad's Avatar
Trader Rating: 198 (100%+)
Here is my tip...... AKA rims( tall,wide and true) AKA foams( are firm and don't suck water) and Proline Calibers( just great) . But don't tell anyone!!
XXXDad is offline
Old 07-02-2009, 05:57 PM
WheelNut's Avatar
AKA city blocks sound like the way to go. They work great on clean hardpack, or on dusty hardpack. I would probably start with the medium compound because they give good life and good grip still, plus if it's really hot at the track the medium rubber won't be overly soft like the AKA soft compound is. The best part about these tires though is that once you wear them out you can cut them open and pull the foam out and reuse them in another set of AKA's because AKA sells their tires without foams and they are quite a bit cheaper without foams!
As far as Panther Komodo 2's go I wouldn't even bother with them. I used to run them all the time a few years back, and I still try them from time to time, but they just don't work very good anywhere. They might be good on a soft damp track. They wear so fast on any dry hardpack that it's just not funny though.
WheelNut is offline
Old 07-02-2009, 07:40 PM
j.d.roost's Avatar
Sounds like City blocks are the ticket to try out 1st. Thanks for the help.
Old 07-02-2009, 08:10 PM
last's Avatar
I use city blocks up front and I-Beams in the rear and if it's hot and dusty I would go with medium which would help with wear also.
last is offline
