-   Nitro Off-Road (https://www.rctech.net/forum/nitro-off-road-130/)
-   -   Novarossi N21BF Limited Edition .21 Off Road 3 Port - Glow Plugs (https://www.rctech.net/forum/nitro-off-road/308094-novarossi-n21bf-limited-edition-21-off-road-3-port-glow-plugs.html)
voodoopapa 06-28-2009 07:47 PM
I've just purchased a Novarossi N21BF Limited Edition .21 Off Road 3 Port. It comes with a standard glow plug head. Can anyone recommend any glow plugs that suite this engine.
I've got a few Axe Rossi standard R6 & R7 plugs. Would these be o.k. Also would the OS 8 plug suite this engine
cheers
TVMRocket69 06-28-2009 07:49 PM
I use the OD purple sport plug in mine
Shane369 06-28-2009 07:50 PM
VeI've been running the odonnell 77 in mine with great success! They are only a few bucks and as good as any plug out there. IMO
rossoh10 06-28-2009 08:18 PM
Run the od77..I was told by a very respectful novarossi dealer to run the mc8 or the od plugs..
Don`t run the os plugs there a shorter plug and not meant for nr engine
I also have a NR limited engine..Can`t ait to break it in..The guy I got it from gave me mc8 plugs to run in it
v6shooter 06-28-2009 08:48 PM
os8 are short.Use as rossoh10 said od 77. The os8 will not reach the combustion chamber
voodoopapa 06-28-2009 09:02 PM
Guys is this the plug you are talking about. I note that it says for .12 engines. Got the description from Amain Hobbies.........
This is one O'Donnell #77 standard glow plug for engines that accept long shaft plugs (basically any engine except OS engines). This is a hot glow plug intended for use in .12 race engines with high nitro content fuels. This can sometimes be a good plug for .21 race engines if you need a hot plug (such as when the humidity is very high).
cheers
Stardust 06-28-2009 09:11 PM
OD 77 for the 21 BF is perfect!!
v6shooter 06-28-2009 09:25 PM
thats the one.
Alan D. 06-28-2009 09:26 PM
O'Donnell 77 or 100 (if you can find it) best plugs for any motor (that is not O.S.) made. Ignore what the descriptions say and listen to your fellow racers.:cool:
voodoopapa 06-28-2009 09:43 PM
cool. just ordered 4. am based in Australia so it will take a week or so to receive. thanks for the advice.
voodoopapa 06-28-2009 09:49 PM
just one other question. am going to run 25% nitro. I take this hot plug will be o.k with 25%. I've always thought the higher the nitro the cooler the plug
cheers
thenova70ss 06-28-2009 09:50 PM
Can you run 30% in the 2001bf are do you need to add a Shim.
rossoh10 06-28-2009 09:59 PM
cheers
Yes you will be ok....
Yes you can run 30% but it would be good idea to add a .10mm shim or take out the .10mm shim thats in it and add .20mm shim.....The shim will help you squeez a little more top end and running 30% also adds a little top end
mbx5rcr34 06-29-2009 02:59 AM
what about a place like (hot) above 90 deg. asian side ,what do you guys recommend ?what plug ??,thks
losiracer78 06-29-2009 04:34 AM
Yes 30% works great in the 2001bf . Thats all i have been racing with is 30% and have 8 gals though it and the only thing that i have changed is a few glow plug. This motor is great. its not as fast as some of the other motors out there but for the price you cant beat it.
