LIFEPO4 RX 6.4V BATTERY >
Old 06-27-2009, 05:30 AM
COBRARACING's Avatar
Default LIFEPO4 RX 6.4V BATTERY
HI GUYS
Just some photos of the lifep04 rx battery (no regulator required )
Im in china at the moment testing the batteries with great results .
Have been tested with 2.4ghz multiple radios including futaba ,spectrum sanwa and ko with no issues .
up to 1400mah so far in hump and stick pack and they are lightweight excellent for buggies with most of the weight in the centre line like xray,mugen hobao etc .
The will not bulge during charging extensive testing has been conducted.
anyway please enjoy
regards Angelo
COBRARACING is offline
Old 06-27-2009, 06:07 AM
vagnik's Avatar
Any words on dimensions and when will they be available?
vagnik is offline
Old 06-27-2009, 06:11 AM
cary's Avatar
Trader Rating: 67 (100%+)
cool this is just what is needed for the Futaba 4pk tx
hope there will be one that will fit in it
cary is offline
Old 06-27-2009, 06:28 AM
Davidka's Avatar
Trader Rating: 86 (100%+)
I saw another vendor somewhere that's doing these. Sound's promising but how do you charge them? I am not aware of any LiPo chargers that allow one to change the output voltage and these would need that or a all together new charger.
Davidka is offline
Old 06-27-2009, 06:40 AM
cary's Avatar
bummer good point my charger only goes down to 7.4 2s
you think you got it then this hobbie bites you in the wallet
cary is offline
Old 06-27-2009, 07:47 AM
markr04's Avatar
See if your charger has a "LiFE" or "LiFEPo" setting. All of my LiPo-capable chargers are also LiFE-capable.
markr04 is offline
Old 06-27-2009, 08:13 AM
Davidka's Avatar
My LiPo charger is a Duratrax ICE, I don't think it's LiFe ready but maybe if this battery type gains popularity a firmware update with LiFe could be in the future.
Davidka is offline
Old 06-27-2009, 03:22 PM
shady3031's Avatar
Trader Rating: 26 (100%+)
Check lithium ion I belive their settings are 3.1-3.2 volts per cell
Also known as a123 cells-li-ion. Which also normally have a lot higher charge rate 2-5c
shady3031 is offline
Old 06-27-2009, 06:55 PM
most chargers of today like will charge the lifep04 example the diamond back ,the bmax ,ice,much more,patrick and others in the software just look find the life is just after li po or lithium ion on the lcd screen most software on chargers follow the same sequence.
But in saying all this we will have a small charger that cusomers can buy with the charger for about $20 US this way you dont have to upgrade your charger at all.
dimentions are as follows
stick pack 84mm L x 24mm W x 15mm H weight 74 grams
hump pack 51mm L x 31mm W x 24mm H weight 79 grams
Old 06-27-2009, 07:52 PM
oldschoolrc's Avatar
isnt 1400mah kinda low?
oldschoolrc is offline
Old 06-27-2009, 08:15 PM
Davidka's Avatar
No, 1400mah is plenty of power. There's no chance of dumping a 1400mah pack in an hour of running. The advantage of this over nimh is that the voltage should stay more consistent.
Davidka is offline
Old 06-28-2009, 05:26 PM
Less spikes ,safer,consistant Linear power distribution , lightweight ,and 1400 is plenty for an 1 hour of racing
Old 06-28-2009, 06:28 PM
so if you get 2 a123 cells (which are 2300mah) that should be all you would need for more than an hour for a 1/10?
why are nihms up to 5000 then?
Old 06-28-2009, 07:02 PM
Well, since this is posted in the NITRO section, and this thread is about RECEIVER packs, the hour of running is in reference to how long these new receiver packs will power the receiver and servos. Not about running a 1/10th electric car for an hour on 1400 mAh.
Stealth_RT is offline
Old 06-28-2009, 07:22 PM
sorry but this line made me wonder
