charging glow igniter on hyperion charger
charging glow igniter on hyperion charger what settings do i use i have a hobbico hot shot 2
i dont have that charger, but
NIMH at 1 amp would do it fine |
Nicd, 1 cell, 1500mah capacity, 500mA (0.5A) charging current or just nicd auto
I charge my hotshots @ 1.5 amps. I have had the same 2 igniters for two years and never had any problems charging like this.
Use nicad or nimh which ever the bat type is and then I charge my igniter at .5 to 1 amp. This charger will peak charge it and then trickle it when it is done. If you want to get reap fancy use the cycle mode for 1 to 2 cycles at 1.0 and discharge and same charge rate.
