os max .21 vz-b v-spec >
Old 04-26-2009, 08:15 PM
Default os max .21 vz-b v-spec
How good is this engine??? how would you rank it with other racing engines??
dreaux is offline
Old 04-26-2009, 08:17 PM
bump
dreaux is offline
Old 04-26-2009, 08:19 PM
RyyRyy's Avatar
Trader Rating: 16 (94%+)
its great but there are a million other threads on this... try a search on it, it will yield alot of threads
RyyRyy is offline
Old 04-26-2009, 08:31 PM
jrwoodchuck's Avatar
i swear by it.
jrwoodchuck is offline
Old 04-26-2009, 08:36 PM
Jaz240's Avatar
Trader Rating: 52 (100%+)
Originally Posted by jrwoodchuck View Post
i sware by it.
Unfortunately his didn't come with the spelling DVD
Jaz240 is offline
Old 04-26-2009, 08:45 PM
ok, fixed it... i went to school for math, not english...
Old 04-26-2009, 08:57 PM
ok did search. yes it yielded a million threads with the mention of the vspec. so i get threads from everything about buy sell, HOT BODDIES BUGGY!!!! Tmax revo!!! CARBON DEPOSITS YAY!!!!!! And endless amount of crap i don't feel like sifting through. I bought the engine today and wanted to get some feedback that is all.
dreaux is offline
Old 04-26-2009, 09:06 PM
ok. anybody else????
dreaux is offline
Old 04-26-2009, 09:20 PM
kaya's Avatar
to late now you just got one for $300.00
so you say in your last post on springs
kaya is offline
Old 04-26-2009, 09:25 PM
RyyRyy's Avatar
sorry to hear that lol... the engine is good, I've been running them for 2 years... If you can't get these to run right then i dont know what to tell you cuz it's one of the easiest engines to tune.
RyyRyy is offline
Old 04-26-2009, 10:30 PM
Joey Powell's Avatar
Put the JX21 con rod in it. The stock rod has no oil hole in it. Your crank pin will thank you.
Joey Powell is offline
Old 04-27-2009, 07:23 AM
Krawl's Avatar
It has crazy raw power, but not long lasting engine I heard. Mine just had 3 gallons on it, so far still very fast, but got a little bit of problem currently, probably air leak...
Krawl is offline
Old 04-27-2009, 05:42 PM
Trader Rating: 15 (100%+)
i don't really know how many i have owned but i will say over 5. They are very easy to break in and tune. Maybe the best in the business. But where it lacks is life expectancy. Maybe if you do what Powell said that would prolong life. Almost all mine when they EVER ghost flame, pull it because there is definately a problem somewhere, most of the time rod slop or crank pin were. I may even try another and put the jx rod in it to start with and see how that goes. another idea, once it looses the tight spot from the metal pinch replace the bearings. An awesome engine if they could get them to about the 6-8 gal mark consistently. To be honest i probably wouldn't run anything else if they could do that.
Jonathan Bell is offline
Old 04-27-2009, 05:48 PM
JAMMINKRAZY's Avatar
Trader Rating: 17 (100%+)
They are awesome!!
Here are some tips for searching. Go to the advanced search page, and select titles only and select the section of the forum you want to search in (in this case nitro offroad) then search with your key words.
Here are the v-spec results
http://www.rctech.net/forum/search.php?searchid=5512958
JAMMINKRAZY is offline
Old 04-27-2009, 06:38 PM
RyyRyy's Avatar
Originally Posted by JAMMINKRAZY View Post
They are awesome!!
seeeee told ya there was threads
RyyRyy is offline
