After run oil
After run oil
Ok guys I tried using the search bar, but it's not working right now.
Red ARO is bad for silicon filled cranks and the clear stuff is fine for silicon filled cranks right?
I remember reading that ATF could be used for ARO. Is this true?
get the GMK after run, its the best and comes with a syringe...
http://www.amainhobbies.com/product_...ducts_id/12719
how do you apply that, yoy put it in your fuel line and start the engine or what?
use a piece of fuel line to the carb, squeeze some in and turn the engine over on the starter box
i like this better than pulling out the glow plug because there is no chance of letting dirt in
nice, same time
its very good oil and is safe for all silicone ramps...
how bad is the red AFO, I used it one time & its sitting in my engine for about 4 days......
