LST2 TUNING HELP PLEASE!!!
ok my lst2 turns on fine but when i hit the brakes all the way the truck shuts off....it happen every time i had to press on the brakes lightly to run the truck can someone help me please
Adjust your idle screw, check for a small gap when you hit the brakes, think it should be somewhere around 1-1.5 mm.
when ever i hit the brakes the carb. closes a bit but doesn't close all the way but it still shuts off the truck.....what is the exact name of the thing i have to adjust
anyone else with some input?
your clutch is garbage...clutch maintence is very important you should tear the clutch down often to clean/replace bearings pads and springs but ill bet money it has to do with yr clutch:nod:
