Can I change the fuel percentage?
sure
You will be perfectly fine
When you change nitro percentages, you will need to adjust your needle settings and also start your break in process all over from the start.
Generally engines don't mind going up percentage, but i think going down is not good.
Do you generally have to richen the needles going up in %
but what happens if going down? is it a bad thing or i just have to re adjust needles?
Just readjust the needles. you are just resetting the needles to adjust for the different ignition timing of the different %'s.
It is just a matter of personal preference but I always found with big blocks that going to a higher % needed a colder plug. 20% I liked a medium plug.
I have had 4 of these engines with the lst2/8ight/muggy.
