The Easiest Way
The Easiest Way
What is the easiest way to find TDC, BDC?
Just take your glow plug out and insert a small straw or something similiar. Rotate your engine until your straw keeps moving up. Just as it move up and stops, that's your TDC. Then it should start moving down and then stops, that's your BDC. If you want you can mark your flywheel so you have an easy reference as to where these points are just by looking at your flywheel.
