Suspension Adjustment Help!
Can anyone give me a link that had Tips/Instructions for adjusting an off road buggy suspension, specifically Track Width, Camber, Toe, etc. I have an MBX5R and I don't believe I've ever adjusted correctly. Thanks for any suggestions.
Here's a great setup:
http://www.mugenseiki.com/mbx5p-setu...5_sh040206.pdf This is for a really rough track though. I'm running this setup with a few changes: Shock Pistons: Stock white F Shock oil: Losi 35wt 6 or 8mm spacer - If it's cold go down to 30F/25R R Shock oil: Losi 30wt 8 or 10mm spacer Springs: Gray front, light blue rear Steering Ackerman: Center hole If you find you need more steering use .5-1.0 toe out in the front And here's the link to Mugens setup sheet library http://www.mugenseiki.com/settingsl-e.htm |
Originally Posted by David Wall
(Post 5513688)
x10....great resource!!!
Start with the setup I gave you above, then using the Hudy guide start tweaking the setup to suit your track and driving style! |
Thanks guys. The help is greatly appreciated.
are u guys really using the fancy setup tools ike that hudy stuff...its always interested me but i just never took the dive into one...and kinda didnt see it being needed...but it looks like after reading that in more depth its can help...i just mic my stuff and what not...so how u guys seting ur stuff up
Originally Posted by mist467
(Post 5514997)
