exhaust headers
Ok I've heard alot of different opinions about this so let's get after it,
L headers vs. smooth curve headers? What one produces more of what? torque? top end? fuel milage? |
They say that ] shaped headers smoothen the power.
I've been hearing different things also. From what I remember back in the old days, it was a common belief that the longer header produced more bottom end torque and, the shorter header was biased towards top rpm.
Now I'm assuming that the "C" style is a long header and the "]" style is the short header. |
Anyone else have different information?
It all depends on the engine, pipe and which header you are talking about. There are too many variables to make any general assumptions.
On the Mugen Ninja JX-21 B01A you can see the difference between the C and L type Ninja headers with the Ninja 2042 pipe on the dyno graphs I posted in the JX21 thread. |
Originally Posted by John Schafer
(Post 5474566)
I always thought the shorter header was more torque???
like when we used to cut a 1/4 inch off of the header on teh nitro tc3 back in the day.. MO |
a short header will provide more top end, a longer header will provide more low end.
Originally Posted by Trevor Williams
(Post 5479797)
Generally speaking more length will give more low end and less length will give more top end. But, the taper and length of the divergent cone on the pipe is also important as well as the diameter of the header vs. area of the exhaust port. But when you make a change to the length of the header, you need to be mindful to match the header length change with a change to the overall length of the entire exhaust system.
And that will be dependent upon the port timing, operating temp, nitro % & plug. To your original question about header bends. Straight s better than bent; curved (constant radius) is better than multiple bends. |
