Ofna Ultra Comp2 Engine issues
So i found a Ofna Ultra Comp2 the other day in the trash(im a garbageman). Brought it home and cleaned it up. I completely ripped the engine apart and cleaned it. I put it all back together and i cannot seem to get it to start.
The pull start was broke when i found it so ive been trying to start it with a start box that i found in the trash(love my job btw) previously. I got another nitro truck so i know how to start an engine but this one wont go. Glow plug is bright orange hot. I turned the engine by hand till i got fuel in the line. Then a few more times to get fuel in the carb. Nothing. I think i see why they threw this thing away. Now i have read that these Force engines are complete pieces of crap. This is the Force .26 btw. What do you guys suggest? Just buy a new engine? if so, can you direct me towards a good replacement. Will my old pipe(assuming its the stock pipe) fit? Not going to be racing. Just bashing. or should i keep messing with this one? |
You should set the HSN and LSN back to factory settings and start there. Not sure what they are but im sure with google you can find them.
Your exhuast pipe will work with another motor as long as its in the .21-.28 range. How much do you want to spend on the new motor? The mach427 can be had pretty cheap $125 or so off ebay, a lot of people like those. Might be a little too much power for a buggy but just make sure you buy a new motor. Other wise you might end up in the same spot. |
The Team Losi Mach 427?
or Dynamite Mach 427? See them both. Or are the same engine? |
Or any other suggestions? Not looking to spend a whole lot. Maybe max $150
Hyper .21 8 port...Balls out power and speed, $120 lasts forever even if you cant tune..Here's a Link:
http://www.nitrohouse.com/catalog/pr...ducts_id=13197 |
motor
Originally Posted by Tfizzle
(Post 5418415)
