.21 Motor????
Hello guys, just need a new motor and im looking for the MOST reliable motor, id dosent have to be the fastest, im in to racing but i want a motor that can finish a 45min race without flaming out on me! BTW i have a OS .21RG motor could it be modified?? because i really like it!! its the best (NOT the fastest) motor that i had, it never flames out on me!!
Thanks Mike |
I have always had good luck with O.S. Engines. Yes you could get it Moded.
http://carolinasrc.com/Webstore/Scri...idcategory=318
Take a look at the silver head GRP, the GRP tuned, RB s7, Vspec, jx ninja. Those are all very good engines. Here are a couple codes for carolinas if they are a shop you use.. rcjan930 $30, $300 or more rcjan965 $65 over $700 |
Mike look at the Vspec, jx ninja, and Nova,NovaRossi N21BF Limited 3. I race with the Mugen Jx Ninja and love it .Its a lot like the Vspec bit it has more mid toq and more high end toq. I also have the Nova Rossi n21bf , its a 3 port and picked it up to play with but gets up and goes as well and you can pick on of those up for about $160. If you looking for a big race motor i would really look at the Mugen Ninja .
Try a Go Tech .21 turbo. They fixed the carb issues and they offer great performance at an affordable price. If you shop around, you can find a new Got Tech turbo .21 for well under $200.00.
Thanks Guys!!!! hey can i use a .21RZ piston and sleeve on my .21RG???? the .21RZ is 4 ports and the RG is 3 and the RZ says 2.4 at 30,000... :D
not sure on that one mike
Does anyone know what kind of performance advantage i'll get by swaping out the crank in my O.S. VZ-R with an O.S. Speed crank?
Originally Posted by Triton3d
(Post 5338996)
Give the Nova .21bf limited a try. A-Main has them for $150. It's high quality Novarossi stuff and it'll make more power with better run time than the RG (I love these too) and it runs best with the same pipe as an RG, which is an 086 or JP2. |
Originally Posted by Davidka
(Post 5339149)
I'm pretty sure you can't, at least not without the matching crank. The RZ has a different bore/stroke, the ports wouldn't be placed correctly.
SH or SH based engines rarely let me down, this ones great for the money:cool:http://www.amainhobbies.com/product_...ducts_id/25386 180.oo bucks once you put in into cart:cool:
Originally Posted by booker686
(Post 5339185)
Is the Novarossi 9886 the same as the 086?
Mike
Nova .21bf limited 3 port is going to give you a little run time between stops. I run mine at 210 - 220 and it was super easy to tune . I have about 5 gal of 30% though it and have never had a prob with it . |
Originally Posted by Tree
(Post 5339243)
Yes they are the same pipe. You can save a little money buying A Dynamite Platinum 086 pipe instead of the Novarossi 9886.
so duz sh make a pipe like the 086
