Rb Air filter set issue... Help. >
Old 01-23-2009, 04:53 PM
Default Rb Air filter set issue... Help.
Does anyone use the Rb air filter set for the c6 l2g? I have it on mine, and I just can't figure out a way to mount it under the body. I mean it just doesn't fit. I have an 8ight with the stock body. If you have it, what body are you using? Or how did you make it fit?
Cvdiver is offline
Old 01-23-2009, 05:29 PM
r1harper's Avatar
Trader Rating: 24 (100%+)
i used a shorter elbow...on truggy the stock one is fine
r1harper is offline
Old 01-23-2009, 05:42 PM
Im sure someone will correct me if im wrong, but Losi designed there air filter for the 8IGHT to be different than the "standard" off-road air filter. I guess there just wasnt enough clearance. Some filter sets simply just wont fit under the factory body.
If no one chimes in with a body that will work with your filter, or there isnt one, here is you best bet....http://carolinasrc.com/Webstore/Scri...idproduct=2677.
NCWC is offline
