Hot Bodies D8 Truggy >
Like Tree10Likes
Old 12-21-2018, 09:13 AM
  #10081
Trader Rating: 19 (100%+)
I have used these posts before:
https://www.amainhobbies.com/losi-bo...osa4433/p34980
With these posts, I was able to use different bodies that have the hood straight.
timberline97 is offline
Old 12-24-2018, 02:09 PM
  #10082
Default JC Silencer body
Still not in JCs website!
gilbertfg is offline
Old 01-14-2019, 02:29 PM
  #10083
Trader Rating: 26 (100%+)
What do you do with the two smaller shims they give you while building the diff cases on the D817T? The manual doesn't say.
bphil49 is offline
Old 01-14-2019, 03:33 PM
  #10084
are you talking about the ones that go on the pinion?
RePeTe is offline
Old 01-14-2019, 04:03 PM
  #10085
Yes
bphil49 is offline
Old 01-15-2019, 04:10 AM
  #10086
muggy427's Avatar
has anyone converted a d8t to a d817t? and whats a good base setup for it
muggy427 is offline
Old 01-15-2019, 01:36 PM
  #10087
Anyone have pictures of the shims on the pinion gear?
bphil49 is offline
Old 01-15-2019, 01:45 PM
  #10088
no pics, but my manual shows 1 shim on the outside of the case, before the circle clip on the pinion
RePeTe is offline
Old 01-15-2019, 01:56 PM
  #10089
Mine doesn't show that. I have one of the first kits out. They must of added that later. Do you mind showing a pic of your manual?
Never mind I figured it out.
bphil49 is offline
Old 03-05-2019, 03:55 AM
  #10090
Hey guys what body's do you run on your hb 817t truggy as the Proline ones are hard to get does anyone easl run different body's or brands on them I saw jconcept one but you have change front shock tower too Uead it or u don't have too
MadMick is offline
Old 03-05-2019, 04:53 AM
  #10091
I'm pretty sure Absolute Hobbyz has the proline in stock still.
flap jack is offline
Old 03-05-2019, 05:32 AM
  #10092
fbrk8r is offline
Old 03-08-2019, 05:09 AM
  #10093
I have a D8T / D817T Hybrid and it runs just as good as any of the other Truggys in my opinion. It still has The D8T front end and chassis but has the D817T rear and diffs as well as the new hard arms. I use the base set up for the D817T as my set up and It runs very good. I don't race it all that often but when I do I feel it's very competitive.
Eastside777 is offline
Old 03-08-2019, 05:17 AM
  #10094
invrtd's Avatar
Trader Rating: 23 (100%+)
Shim the diffs according to backlash. I normally add one shim under the bearing for the pinion. This pushes the pinion in the case a hair. I than shim with one or two shims the side of diff itself depending on backlash. If you don't shim your diff properly, it will eat itself.
invrtd is offline
