Hot Bodies D8 Truggy
#181
Mines on backorder!
Pairing it with a Mugen Jx.21
#186
Jesse Robbers ? Is all the r & d done with and designed with the titanium screws in mind?
#187
I've never had a HB bladder tear or break, when they get old they sort of get a little flat though. With the 103.5mm buggy droop, I've never had the nut hit the bladder so it'd tear it. I use a longer shock bottom which pretty much keeps the shaft from hitting the bladder b/c it limits the uptravel a bit. If you just unscrew the stock shock bottoms it'll allow the shaft to extend further into the body hitting the bladder. So try putting the HB D8 steering ballcups on the bottom of the rear shocks, trim them so they are 1-2mm shorter, and screw on enough so you have the shock length you want.
#188
thanks for the shock info ^
#189
Can't wait for this kit to hit my door step, Jesse I know you guys have to be enjoying yours! How many days a week do you guys practice/race?
#192
Go for the d8t and make yourself happy......take the $300 put it towards motor or whatever else you need and kick some a$$ with the D8 like were going todo
#193
i am kind of in the same boat as you. the 2.0 is tried and tested. but really not that different from the 1.0 just longer and longer shocks. the D8T is looking like a real contender for the money you save and hot bodies is a great company.so save some money and spend it on extra parts or upgrade your gear, 300 is a lot to save.
#194
When im out on tha track and see all these T 2.0's while i have the D8T out and they are saying.."Man my T just aint doin it for me"...only words i will say and then walk away are.."Should of had a D8T"..then sling dirt up on there T's from the D8T. the look on there face will be similar to this probably and some of this
I'll look like this
#195
