HYPER 9 SET UP INFO.....
Has anyone got any set up info on this new 9??
What Diff oils to run?? What shock pistons & shock oils?? Is the kit set up ok.. Any tips?? Thanks.. |
check out the Hyper 9 section in the ofna forum, I'm sure you'll find good info..
http://ofna.com/forum/viewforum.php?...d24d2d4bf1b79c |
most are starting with these tips for a base set-up, good information here:
http://www.nitrohouse.com/catalog/articles.php?tPath=10 |
Thanks guys.
I know of the ofna site but would like some info on RC Tech. Is the kit set up any good. Thanks.., |
havent really heard of anyone using the out of the box kit set-up, althought it is fairly close to the recomended set-up on nitrohouse. most use the nitrohouse set-up cause it has been tested alot by Tim Bump, Jeremy Kortz, and Robin Nelson. I suggest using the nitrohouse set-up as a starting point and then make changes one at a time to get it like you want it!!
i m searching for JEREMY KORTZ set up, some one have it?
