jammin jpx .21......whats the BEST pipe?
I really liked a JP1 on it. But the JP4 performs very well on it as well.
Ofna 053 pipe. Best pipe for that motor Hands down. Same as the dynamite/werks.
the 086 is the best pipe...best mix of low and high end..... 053 is okay, but falls off on top compared tot he 086
JP-1! That engine has plenty of high end, so the JP-1 is a good combo..mine rips!
Wow so many different pipe preferences !!!!!! just shows how versatile this motor is !!!! JPX .21 ROCKS !!!!!!
IMO the Ofna 053 is the best. Yea, you loose a tiny bit of top end compared to the 086, but IMO what you gain makes for quicker lap times...I also liked the JP2, but not as much as the 053. The JP4 is very smooth, and deceptive, and has a stupid top end, so it is a great choice as well.
Most will pick a pipe based on the track they run at. So that might be the reason for the varied responses...You might want to do the same. Check out the track you're going to be running on, and based on the tracks size and traction, you should be able to better decide what will be best for you...
It really depends on your track(s).... or rather, where you want the powerband to be. If you're looking for all out speed, go with a pipe tuned for more topend. If you have a small/technical track, a low end or medium range pipe might be what you're after.
Don't forget the Picco 2046 also a verry good pipe for that engine
heres a video of one of my modified JPX .21's on a 086 tuned pipe...
http://video.google.ca/videoplay?doc...30492447570837
That thing is smoking down the back straight, it clears jumps with ease, nail it and watch it fly.
Nice work mate, keep up the good work.
