RB C6 LG2 Murnan modified off road
Anyone has any experiance with this motor? In my opinion this could be one of the best off road engines ever made.
Murnan modded RB C6 L2G
We have run this engine that was modded by Murnan for about 2 gal. and all I can say is WOW. the engine runs cool @210-225 with 9 to 10 min run times and much more punch than the stock one.We run ours in a Mugen Truggy,I would imagine a buggy with this mill would be awsome. Try It you will love It
I run a standard C6 BB in my truggy. And its a handful. And when I run it in my buggy, and its way uncontrolable. It is fun to try though.
Chuck |
rb c6
So how much better is Murnan moded C6 vs stock C6 one. I am planning to buy that engine, so is it worth paying that extra cash? I realy need powerfull and reliable race engine for my rc8t.
I mod c6 will be faster then ballssss... but it would be nice to have but not worth the money to me
what are you gonna put it in?
I have a modded c6 that I run in my buggy and get 9 to 10 mins out of a tank. The motor is super smooth and has tons of power. It makes driving a buggy a hand full. I also have a os speed that I run in my buggy and the c6 out performs the speed hands down. The c6 has way more bottom end punch. Just my 2 cents
Why on earth would you want to mod that motor? I have a c6bbt l2g in my 8b, and all I can say is do you really need any more??????
actually modding usually makes an engine smoother and more controllable, even though you get more power
Well, Im gonna put it in my truggy rc8t, in the past had two grp 28(never ever again-little too fast,not reliable at all after 2nd gallon mark, just cant get it right), had two novas-Hot mod 28xr (too powerfull for racing,died after 11 gallons-very delited, the second one still running at 8 gals. ), had Axe Rossi Cobra evo x1(nice engine, but realy just not enough power, also broken conrod after 2nd gallon mark-also never ever again), now i have full moded extech24, great engine for truggy, but just wanted to try another 21 with overall more power than Axe Cobra.
that would be a pretty good choice for truggy, you might wanna also check into the ninja jx, it has a ton of bottom they work well in truggies also, and have great top end as well
Originally Posted by cjm1126
(Post 5182837)
Or a novarossi plus 21-5k. You can get them for $270 on amain which is a killer deal. They normally retail for around $335. One of the smoothest most powerful engines I have owned. And you know from your experience that novas last forever. |
Originally Posted by Cvdiver
(Post 5182739)
well i am sure that it will have tons of power.. maybe a little to much
(Post 5182752)
Originally Posted by big_klemo
(Post 5182928)
I got it modded just to try it out and it made the motor way smoother and I like having all the power it makes racing fun for me
It made the motor feal smooth across the curve from top to bottom I found that the bottom used to hit quite hard and this mod job seemed to help this out I run a little stiff clutch set up and I ran the same set up stock and modded and I like the modded on better. My only complaint would have to be is the motor likes to load up a little quicker from being modded.
I have a C6 that was modded by Maxy. The motor is very controllable and gets over 10min.
[QUOTE=Cvdiver;5182739]Why on earth would you want to mod that motor?
Because you can! :batman: |
[QUOTE=CanyonCarverR1;5186547]
(Post 5182739)
(Post 5182739)
muran modified is a great company. uriah is a very nice guy and his work speaks for himself. it may seem pricey but once you get to run the motors they modify. its worth every penny. :nod:
Originally Posted by Maximo
(Post 5186622)
Truly depends on the track surface you run on..on a slick surface a C6 feels like a beast, however on a high bite surface a C6 can be a little to mild on the low end...... The C6 has huge amounts of power left on the table with its design and is capable of making huge increases in power with the right modifications...Now most modders will never really see what a C6 can do, as most do not get into retiming sleeve ports...However if someone is interested in making a beast the center exhaust port on the C6 needs to be brought up to match the eyebrow ports, approx 14 degrees needs to be added to the center port. Once this port is opened up all I can say is Lookout !!! stock because of the exhaust configuration I think they are too mild for my applications...
