holeshot tires
depends i was going threw 2 pair a week on a hard packed track in a t4 with a novak 6.5 7 min runs u could see wear after the first 7 mins also
i wont even get them any more cause they just go bald way to fast it takes longer to mount them than they last.
Depends on the compound and the track... If you are running a soft compound on a dry, hard track, they aren't going last long at all. If you will wait for them to water it, the tires will last longer. Personally I like holeshots with some wear. You might try a set of panther clay switches. Those things seem to handle about anything and hold up fairly well.
if you need a small pin that lasts and has great traction, get the AKA Gridiron tire...
40+ minutes at SRS if your racing at the highest level
and switches wont work for the track your talking bout
