Mugen MBX6T
#1501
Sorry i have no idea.. Try this thou
http://www.myrcbox.com/?p=955
Since i cant post my hudy book cause i dont have a scanner atm
Dave
Dave
#1503
on the caster, if you move the upper arms forward and take away caster the truck will gain steering entering the corner but will loose some on exit. you can cheat this by going up on the front diff oil so the front end pulls the truck off the corner but with the thicker oil rotation will be slower in the center of the corner. most of us are running the a arms in the middle upper and lower. on a slow,tight track you can move the upper shock location out 1 hole from center to gain steering entering the corner. i have the truck setup pretty much stock but the diffs are at 7 7 7. ive tried alot of combos with diff oils/springs/shock oil/toe blocks/arm loc/bars, the diffs really made the truck very easy to drive with steering and just like the car 5 5 5 it squares up and comes off the corner.
#1504
Got some pics of my body for my MBX6T today from Paint Monster Air Brushing. Since everyone calls them a Mooogen I kinda went with it.
Here are the pictures:
#1506
It's what alot of people do. I know when I buy a kit I strip it down in key areas to make sure everything is right. When I worked at a hobby store it was very rare a vehicle had zero issues out of the box. What I mean buy that is diffs filled right, shocks filled right, no broken parts out of the box, no missing parts, etc.
#1507
might be a bit early to ask, but is the only difference between the Kit and M-spec is M spec being pre-build. Any difference in parts?
#1508
#1511
drifting diff oils
What would be the best diff setup for this truck if you wanted to drift??
#1513
Ok thanks, what would be the best diff oils for the buggy if you want to drift????
