ceramic bearings cleaning tips??
i need help with cleaning some ceramic bearing on my losi 8. i used to clean the metal bearing by removing the sheilds and soaking in alcohol and then using compressed air to blow out and then oil. so what are your ways? and what lubricant do you guy's use. i'm using dry ice . any suggeations are appreciated!
TKO sells some good lubes...
some dudes use a jewelery cleaning machine with a citrus type cleaner for the liquid
i spray them with a compressor and gun shooting simple green and water under pressure through them, then just air and I use Odonnel lube!
