AKA tires
#1786
aka compound identification ?
Hello ,
How do I tell what compound I have by the color dot on the tire ?
what color stands for what compound ? is there a chart someplace to compare. Thanks
#1787
Hard - Yellow
Medium - Blue
Soft - Green
Super Soft - Orange
Clay - Pink
Medium Long Wear - Blue & Yellow
Soft Long Wear - Green & Yellow
SS Long Wear - Orange & Yellow
Medium - Blue
Soft - Green
Super Soft - Orange
Clay - Pink
#1788
Those of you running crosslinks on stadium truck have you found out that they are a little too aggressive for the front? I have a set on my T5m and boy does it have some steering. I'm thinking about buying a set of chainlinks just to put in the front to see if it calms the steering down.
I run crosslinks in the rear and chainlinks in the front of my b6d and like it.
Just wondering your thoughts.
#1789
R/C Tech Elite Member
Trader Rating: 123 (100%+)
#1790
Need tire advice, running soft I beams on my 1/8 Etruggy and Ebuggy and they work the best on our practice track. My daughter has a SC10 and I am getting an RC10SC5M for Christmas, so which short course tire corresponds to the I beam? It is hard pack dirt that doesn't see a whole lot water.
#1791
Hard packed dirt and you are running ibeams? Why not try medium gridirons or medium zipps? Ibeams are for loose loamy tracks that need to be able to cut through the loose stuff
#1792
Well maybe hard is not the right word. This is my practice track in the back yard. It is 70% dirt and 30% combination of low cut grass and top soil. It was all packed with a skid steer as it was built, and gets packed with a lawn tractor with weights every time it rains. So as it dries out the dirt part stays packed but gets a layer of dust on it. The top soil gets a little loose. The soft I beams work really good when it is dried out a little to dry and work decent when its freshly packed and damp. I have tried M3 Blockades, soft Impacts, medium Enduros (have these tires for tracks I race at), and Badlands XTR. The Blockades, Impacts and Enduros work great when its wet and freshly packed, but once it dries out they suck. The Badlands only work when it is extremely dry. So trying to find a tire that will work with the 2wd SC trucks without buying a bunch of different sets to try. Something like the soft I beam.
#1793
Lee
#1794
Thank you Winner's Circle
#1796
On a a positive note the impacts in soft are the best tire imo ever made! I can drive with that tire in Cali everywhere and it’s amazing how great the car feels at high speed with that tire because it’s such a fast fast tire. City blocks are a good comfort tire but don’t like others make u think it’s that good because it’s not it’s a slow tire that helps overcome bad setup and be comfortable, it’s absolutely not a fast tire.
#1797
Impacts for loose loam, perhaps Gridirons II.. would really need to see the track, but check out their tire guide. 1:8 Buggy Personally I like the Super Soft/Soft Long Wear Double Down on slightly dusty and/or blue groove.
Referring to the poster above me... I would disagree about their pre-mounted glued tires, the current quality is excellent. Now perhaps you got a bad set in 2011, who knows. But I've had nothing but good experience with them and have also heard good things recently about their premounted. Although I currently tend to glue my own because I get them in bulk.
#1798
#1799
