Adam Drake talks about the new 8ight 2.0
#226
you hadn't posted what servos your using so it was the only thing I thought maybe causing the problem.
Hope you get it sorted
Adrian
#227
No worries bud....i shaved the guard and its all good...buddy's gettin a 2.0 in a week or so and ill be doin the final build on it....so ill have a 2nd kit to compare mine to....Ill let u boys know what i find.
#228
What needs to be done ?
Moved mesaage to the Eight 2.0 thread
#229
http://www.upgradercshop.com/mm5/mer...mvc?Screen=VID
Some good random vids of the losi crew in action at Hotrods...
#230
Fluke- No plans for a conversion kit. email me your address [email protected]
bustedpiecerc- It sounds like the low seed needle is too lean or your clutch springs are too light.
aburton- See you soon!
chill will- Yes, but you also need to change the side gaurds and linkage.
brian kadow- ?
briguy- Radio tray, and linkage.
TIX- Yes, but you will need to drill the outer rear hinge pin hole on the arm to 3.5mm.
brian kadow- ?
#231
Just havin some fun with Burton & Chill Will.
#233
hey burton its laquan
are you guys upgrading your 8t with 2.0 parts
if so whats the parts list
#235
brian kadow- ?
They want you to buy a new kit even if you just bought the 8ight. I know it's not Drakes fault, but I thought I would just put in my 2 cents.
#237
#238
Bigedmond- It’s possible if sales take off. I would rather run truggy personally.
Intergra- Haha..
TIX- The material, mold configuration, design and molding process.
R1harper- Thanks!
Mr. losi- 2-a front and 2-b rear.
Merciless- My buggy was a little over 2 oz. lighter.
Dirtydezpirate- I’ll be at Revelation tonight and Thursday if you need help. What was the engine running at before you switched fuel?
Blower Uper A I haven’t used a nosram or hpi engine.
Donut92673- No problem. Let me know how it runs this weekend.
Jamminfrazy- I’m sure we will release a new turggy at some point, but I don’t know when that will be.
Bigedmond- WOW, 403!
Intergra- Haha..
R1harper- Thanks!
#239
try turning the HSN a little more. Maybe around 1/2 turn and see how it goes. You can always lean it slowly if its too fat.
#240
hey adam i have a quick question and a problem.
how often are u at the nitro pit in az??? i just started racing not long ago and would like 2 see u and mike race, im going 2 tucson this weekend for "The Az Champ series"
and here is my problem. i have the original losi 8ight, i do plan to get the 2.0 but im tight on money because of this problem. i have gone thru 4-5 clutches in the past month, month in a half.My clutch bearings are lasting a night of racing and thats it. i have finally started changing the bearings after a night of racin but i dont feel this should be doing this. ive had 2 different hobby shops take a look but they dont know why. i was runnin the pro kits clutch set up but now i changed to all alum. pads and silver springs hoping this will help
