-   Nitro Off-Road (https://www.rctech.net/forum/nitro-off-road-130/)
-   -   Jammin BB's on Kyosho WC Buggy???? (https://www.rctech.net/forum/nitro-off-road/244062-jammin-bbs-kyosho-wc-buggy.html)
dirtbikekid2 09-24-2008 12:14 PM
Anybody using the Jammin BB shocks on the Kyosho WC buggy? Will they fit, not sure of the length between the two as I'm trying to save some $$$$ cause the Kyosho BB shocks are expensive!!!!! Thanks!!!
DOMIT 09-25-2008 07:34 AM
I'm pretty sure the Jammin shocks are a little shorter... however, it MIGHT work if you put the Truggy ends on them. (Truggy and buggy use the same shocks with different ends...)
DogboneS 09-25-2008 11:09 PM
The Jammin BB's come with both ends. I run them on my WC buggy. I don't run full droop, but you do loose 1-2mm droop with the Jammins when built to Jammin instructions. The shafts screw very deep into the lower ball link(you could screw them in less). I use the white springs, Mugen 500F/450R.
DogboneS 10-03-2008 08:14 PM
http://i99.photobucket.com/albums/l2...108_182300.jpg
'bout time I got a pic up...
Sonic Gear 10-04-2008 08:55 AM
does it rub against the CVD ??:confused:
DogboneS 10-06-2008 05:07 PM
Has not rubbed yet
http://i99.photobucket.com/albums/l2...6/DSC00815.jpg
http://i99.photobucket.com/albums/l2...6/DSC00812.jpg
http://i99.photobucket.com/albums/l2...6/DSC00813.jpg
http://i99.photobucket.com/albums/l2...6/DSC00814.jpg
Powered By: vBulletin v3.9.3.6
