got a question about overheating >
Old 09-10-2008, 05:51 PM
Questions?? got a question about overheating
I got a T maxx with a 2.5R and its had about a gallon or so of fuel ran thru it since break in, and the last couple times that I've ran it, its been running strong for about five mins or so and then starts to bog and slowly bogs so much that there is almost nothing there for throttle, also starts to overheat after boggin. Now its never done this before, I clean the air cleaner air filter after every run and try to keep a strong glow plug in it. Plus I've never raced this motor. could this be a fuel mixture issue? cause I've tried to richen and lean the mixture to try to fix the problem. any suggestions?
prophet1978 is offline
Old 09-10-2008, 06:29 PM
imaxx21's Avatar
sounds like an air leak..
are there any spots on the engine what are wet with fuel?
imaxx21 is offline
Old 09-10-2008, 06:53 PM
bigsquidracer's Avatar
sounds like my os rg does it die after you start it an go
bigsquidracer is offline
Old 09-10-2008, 10:00 PM
Trader Rating: 208 (100%+)
Check the front bearing. If it is wet you need to replace it. It leaks air causing your engine to run really lean. Even if you richen the engine it will run like crap.
dodgeguy is offline
