RB C6BBT, what other plugs can I use? >
Old 07-30-2008, 03:09 PM
Default RB C6BBT, what other plugs can I use?
Just wondering if anyone can list what other brands of plugs you are using with success in your Turbo C6's.
RB Plugs are costly and scarce in my area, any input is appreciated.
I also plan to run Byrons Gen 2 30% Nitro, should I be adding a headshim. I am at sea level.
Thanks Sean.
savagebeing is offline
Old 07-30-2008, 03:12 PM
O'donnell and Rossi plugs will work.
OS plugs won't.
Yes, I would add a .1mm head shim.
largeorangefont is offline
Old 07-30-2008, 03:18 PM
wingracer's Avatar
Trader Rating: 24 (100%+)
Any nova made plug, Novarossi, RB, JP, Top, Rex, etc. Do NOT use OS plugs. Haven't tried Odonnell.
wingracer is offline
Old 07-30-2008, 03:20 PM
wingracer's Avatar
Also, the C6 should run fine on 30% without adding a shim but since you are worried about plug prices go ahead and add it. Plugs will last longer.
Old 07-30-2008, 03:59 PM
Thanks for the quick reply guys.
Cheers
Old 07-30-2008, 04:02 PM
jamminnay's Avatar
the odonnel turbo plugs are pretty good and seem to last a long time
jamminnay is offline
Old 07-30-2008, 04:23 PM
Trader Rating: 25 (100%+)
Just woundering, why dont o.s. plugs work for the c6?
Pete G is offline
Old 07-30-2008, 04:24 PM
Just wondering, why dont o.s. plugs work for the c6?
Pete G is offline
Old 07-30-2008, 04:25 PM
The taper is different on OS plugs. FYI - Standard OS plugs are shorter than normal plugs.
Old 07-30-2008, 04:31 PM
wingracer's Avatar
OS plugs will fit and the motor will run fine but due to a different taper they may leak. If you crank down hard to try and kill the leak you will distort the taper in the head and then all other plugs may leak.
Old 07-31-2008, 07:39 AM
OS plugs won't.
I was under the impression that the O'donnell Turbo plugs worked in the V-spec, which would contradict using them in a Nova based engine...
Can anyone comment on this?
Old 07-31-2008, 05:32 PM
imaxx21's Avatar
OD97T is the only plug you need to have
C6 runs great on it
imaxx21 is offline
Old 07-31-2008, 10:08 PM
Oasis's Avatar
Trader Rating: 38 (100%+)
Isn't the Dynamite plug the same as the O'donnel..
Oasis is offline
Old 08-03-2008, 03:42 PM
If you run 30%, Rb and Rody reccommend an extra head shim.
www.rb-usa.com check out the forums, many times this has been answered.
I have an OS plug in my C6L2G and am having no problems, yet anyway....
good luck with yours!
Cvdiver is offline
Old 08-03-2008, 09:02 PM
smb17's Avatar
Trader Rating: 17 (100%+)
How many shims come with the WS7III standard plug? I got mine used I just never fucked with it and been running 30%.
smb17 is offline
